My GLK12232-25SM is dead! - i've only had it 5hrs! (FIXED)
- LCD!
Ok so my GLK12232-25SM seems to have died on me
It was working perfectly then after an hour or so of fiddling with plugins and trying to work out how to do things i had a problem! I was running the WinAmp2 plugin that is meant to display graphs and things on the display, and then all of a sudden my display just turned off - No backlight or anything.
I tried rebooting and nothing happens at all
HELP!
Thank-you
HELP!
Thank-you
- LCD!
- LCD!
- LCD!
hi,[PCA]Matthoulb wrote:What would be the best font to use for this display? Ie. a nice small one so that everything actually fits
i like to use the Clean font, and a font i created from Clean, called "Clean Inverted", which is, you guessed it, clean, but inverted so you can use it on filled backgrounds. bascially i just loaded Clean into photoimpact 5 and did a batch invert and save, bingo.
- LCD!
Could you contact me on MSN/ICQ? as i don't seem to be able to get hold of youi like to use the Clean font, and a font i created from Clean, called "Clean Inverted", which is, you guessed it, clean, but inverted so you can use it on filled backgrounds. bascially i just loaded Clean into photoimpact 5 and did a batch invert and save, bingo.
MSN: matt@houlbrooke.co.uk
ICQ: 50754046
Thank-you
email me @ dexter750@hotmail.com[PCA]Matthoulb wrote:Could you contact me on MSN/ICQ? as i don't seem to be able to get hold of youi like to use the Clean font, and a font i created from Clean, called "Clean Inverted", which is, you guessed it, clean, but inverted so you can use it on filled backgrounds. bascially i just loaded Clean into photoimpact 5 and did a batch invert and save, bingo.
ICQ: 50754046
Thank-you
i lost my smokinmhz.com domain because i forgot it expires
OUCH, that sucks.
