Question:
Can LCDC and Smartie be running at the same time? (as they are two difference programs, but are addressing the same device)
And can Plug-in from Smartie be used at the same time LCDC is plug-in are being used?
If so how do you go about performming this?
Remember I am new to LCD's so don't be to hard on me :)
LCDC and Smartie
"Was there something in particular you want from smartie in LCDC?"
No there was nothen in particular I wanted from Smartie, just want to try a little mixing if it was possible.
So I will just stick with LCDC I got everytime working for me now E_mail, WinAmp and the GPO's.
I have WinAmp set up to Flash and Strobe over four 4 led's when playing.
I will be posting pictures in the next few days under the Lian-Li section.
Again thanks for all the help as I know some of my question may have seem off the wall.
As I am retired and sit up all night trying this and that and I am slowly getting it down. (My wife think I am nuts)
Talking of LCDC and Smartie...
My MO display is running through a USB/serial converter. The converter is set up by default as COM3 (I don't think I can change this). Smartie will allow me to set the COM port correctly and drives the display properly. LCDC will only see COM1 COM2 and COM5 (there is no COM5!). I suspect that LCDC is detecting the ports and is not seeing the USB COM port correctly. Is there a way of forcing it to see that port? If not, could we have a Manual Setting option?
<font size=-1>[ This Message was edited by: jonahall on 2002-09-15 04:00 ]</font>
There is no COM5! That's the problem, coz it doesn't find COM3 (which does exist) but COM5 which doesn't...
I must admit that I have been playing about swapping devices in and out - I am running an ancient Wacom tablet (which only wants to use COM1 or COM2), the MO display and a modem. The solution should be to put the modem on the USB converter, but for some reason it will only work for a while and then it gives up.
Have I allocated COM5 to something somehow? It doesn't come up in the Windows System display? And I can't change the COM port of the USB-Serial convertor in 98SE unfortunately...
Any ideas?
LCD Smartie seems to crash with depressing regularity :-(
Any ideas?
