I plan to embed an LK162-12 16*2 LCD in my USB keyboard The keyboard's got an internal USB hub with a spare channel and plenty enough power to drive and backlight the display, but this will obviously require the use of a USB to Serial adapter. Can anyone reccomend such an adapter that will work in a relitively painless fashion with this display under Linux? Obviously, smaller is better, since this thing's getting shoved into a small space, but any setup that has been tested to work is worth noting.
-Andrew
USB to RS232 adapters
Well, I found one that seems to work; a cheap generic brand PL2303 based adapter, which, once stripped down, fit easily in the small space. It also helped that it didn't require an external power supply.
Here's the finished project, horriffic Dremeling included. To get everything to fit, I had to remove the display's serial backpack, and reconnect it with a nice long ribbon cable, after removeing all the connectors and headers from it. I completely Dremeled off the GPO's, and also took a few millimeters off the display's PCB itself, completely destroying any imagineable warrenty this thing may have had :-P
The connections are soldered via the USB-to-Serial adapter directly to the keyboard's internal USB hub, and powered off the same, so there are no external connections. It seems so far to run under both Linux and Windows XP as well as if it were connected directly via serial(except with LCDProc, apparently due to a bug that some other people have seen as well).
http://24.88.123.54/tempshare/lcd3.jpg
The cutting is a bit sloppy to look at, but given that this is the first mod I've done which was more sophistacated than putting LEDs in things, I'm satisfied with the way it came out. :-)
-Andrew
-Andrew
- LCD Guru
I used one for my new lcd and it works a treat . Where are you based if its in the uk I can give you a link to the product I usedOn 2002-05-07 21:03, Beaucoup wrote:
-Andrew
I'm in the United States; I got the adapter cable from a locally owned retailer here(CompuForce, http://www.cforce.net/). The device is made by a company called Manhattan, and seems very similar to high-speed USB to RS232 adapter that Keyspan makes, except this one only set me back $30 US :-).
Hi to u all this is my first post i'm waiting for the arrival of my display i got my serial to usb adaptor from the UK http://www.greenwicheshop.com
- LCD Guru
