Join us on Twitter Join us on Facebook Meet Orbie THE DOG!
Home FAQ Profile Search Members Groups PM's Register Login/Out SmartFeedSmartFeed
LK204-25 and Arduino Mega
Last Thread | Next Thread  >
Post new topic Reply to topic
Matrix Orbital > LK/VK/PK/MX/GLK/GVK Series
Author Thread
Jacqmaster
LK204-25 and Arduino Mega  Reply with quote
I just bought the LK204-25 and its default setting is RS232 mode.
I connected the LK204-Rx pin to Arduino Mega Tx1 (Serial1) and get 5V power from Arduino as well.
When power up the module, I can see the default startup screen.
But when I run the below tiny program, the result totally awkward.
void setup() {
Serial.begin(9600);
Serial1.begin(19200);
Serial1.flush();
void loop() {
if (Serial.available()) {
Serial1.print(Serial.read(), BYTE);
Serial.flush();
If I enter "a" from Arduino serial monitor, the LK204 LCD will display "0" on it.
Can someone help me out?
Post Mon Mar 08, 2010 12:55 am
 View user's profile Send private message
I suspect the Arduino is operating on TTL levels
Post Mon Mar 08, 2010 4:33 am
 View user's profile Send private message Send e-mail Visit poster's website
Jacqmaster
quote:
Thus, I just need to add MAX232 driver between Arduino and LK204 to converting the voltage level, am I right?
THanks,
Post Mon Mar 08, 2010 12:16 pm
If you have a steady hand you can also move the zero ohm resistors on the back of the module from rs232 to ttl.
Post Mon Mar 08, 2010 12:20 pm
Jacqmaster
Finally, I added one MAX202 circuit and it works greats. But I got another while connecting to a 4x4 keypad. When I short R1-C1, the LCD will display 246, R1-C2 =>61.
How can get read the keypad map such as R1-C1=>A, R1-C2=>B
Post Fri Mar 19, 2010 11:52 pm
Hi Jacqmaster,
It sounds like somehow the EEPROM in your display module has been corrupt. By default, the keys should be transmitting those that are depicted in the tables on page 40 of the manual .
By using Assign Keypad Code command (254 / 213) you should be able to assign any values that you want the display to transmit when certain key combinations are shorted (depressed). See section 9.9 of the manual.
I hope this helps,
_________________
Post Tue Mar 23, 2010 7:43 am
Jacqmaster
quote:
Originally posted by Raquel
Hi Jacqmaster,
I hope this helps,
May I ask one newbie question. In Arduino, I have to send separate commands in order to achieve the execution. for example,
Serial.print(254, BYTE);
Serial.print(213, BYTE);
but now I am not sure to issue command correctly.
Serial.print("ABCDEFGHIJKLMNOPQRSTUVWXY");
or some other formats.
Post Tue Mar 23, 2010 1:59 pm
Hi Jacqmaster,
Text will be sent out to the serial port in the same way as commands. I'm not familiar with the Arduino language but you might try sending ('A', BYTE). If that fails you may be down to looking up values, such as (65, BYTE), I find ascii-table.com can help there.
To make things a little easier, you may be able to go with an array, something like BYTE mydata [2] = {254, 213}; and throw the serial.print into a for loop to spit out the bytes one by one.
Anyway, you may want to sift through our app notes on the matrixorbital.ca site for a little inspiration, and feel free to throw up another post if you get hung up again.
_________________
Post Wed Mar 24, 2010 9:59 am
â
Forum Jump:
Jump to:
The time now is Tue Sep 07, 2010 6:14 am
  Display posts from previous:
Powered by phpBB: © 2001 phpBB Group
Visit the Matrix Orbital Web Site
