HTT HDMI TFT Support Utility
Posted: Thu Apr 09, 2020 3:31 pm
by Henry
We are happy to release our HTT HDMI TFT Support Utility source code for Windows and Linux!
Source code for Windows and Linux
Windows compiled version
User Defined Settings
Screen Rotation: 0, 90, 180, 270
Touch Panel sensitivity: Normal, High, Extra (thickness is dependent of display)
There commands require PCB 2.0+ of any HTT display
Backlight Brightness: 0-255
Haptic Feedback: Duration, ms
Piezo: Duration, ms
Touch Feedback: 0 none, 1 Haptic, 2 Piezo, 3 Haptic & Piezo
Backlight Auto Dim: dim from last touch, seconds
Re: HTT HDMI TFT Support Utility
Posted: Fri Aug 19, 2022 12:13 pm
by thebigkahune
I am able to compile this utility for linux however htt_util --scan does not show any devices. as a sanity check i verified the device is visible on windows with the precompiled binary. I can also see the device is loaded using lsusb. Any tips on getting this to work in linux?
-Doug
Posted: Mon Aug 22, 2022 12:30 pm
by Ray
Likely a permission issue imposed by the OS, can you try with sudo ?
If that works you'll have to add a udev rule to give users permissions to touch the device :
ATTR{idVendor}=="1b3d", ATTR{idProduct}=="14c9", TAG+="uaccess"
will likely do it, but i don't have system to test this on at the moment so you may have to get creative here.
Posted: Wed Aug 24, 2022 11:05 am
by Ray
Found some time to test on Linux, the following udev rules will allow regular users to use the htt utility
SUBSYSTEM=="usb", ATTRS{idVendor}=="1b3d", ATTRS{idProduct}=="14c9", MODE="0666"
KERNEL=="hidraw*", ATTRS{busnum}=="1", ATTRS{idVendor}=="1b3d", ATTRS{idProduct}=="14c9", MODE="0666"
