I2C Stops Working
iotexpert.com
I2C Stops Working
Post by iotexpert.com » Sun Apr 29, 2018 5:07 pm
I am able to talk to the GTT43A via Serial and via the Mass Storage.
I am no longer able to talk via I2C.
For the life of me I can't figure out what I could have done to turn off the I2C.
Does anyone have any idea?
Re: I2C Stops Working
Post by Daniel Divino » Mon Apr 30, 2018 9:55 am
Hi iotexpert,
Are you unable to read and write data to the display at all? When a clear screen command (254 88) is sent to the GTT, does it respond at all?
iotexpert.com
Post by iotexpert.com » Mon Apr 30, 2018 1:36 pm
I can still write to it via the serial port... yes... using the UART I can send 254 88 and I get a clear screen... and I can read as well.
What I cannot do is talk to the display via I2C.
All writes and reads of the device are NAK
I suspected that it might be a power problem (from another thread) so I connected to a big external supply... when I did this, it fixed other problems that I was having... but the I2C still doesn't work.
I am assuming that there is some configuration setting that I did that break it... but when I remove autoexec that doesnt fix it... new firmware doesnt fix it... old firmware doesnt fix it...
When I connect the logic analyzer I can see the writes are happening correctly from the PSoC development kit that I am driving the display with... but no response... only a sea of NAKs
I suppose that I might have blown up that port? It is frustrating (as you can tell by my other post that I got the I2C working earlier in the weekend)
Alan
Post by Daniel Divino » Tue May 01, 2018 9:11 am
Hi Alan,
Have you changed the GTT's i2c address at all? Also, are pull-ups present on both the SCL and SDA line?
iotexpert.com
Post by iotexpert.com » Tue May 01, 2018 11:19 am
Yes I have tried multiple I2C addresses.
Yes I have 2.2K pull-ups... (it was working).
Is there some setting that turns I2C on/off in the screen? Could I have changed something?
At this point all I can figure is that I blew up something.
Alan
iotexpert.com
Post by iotexpert.com » Thu May 03, 2018 9:40 am
Well.
I got a new display today. I plugged it into the same setup and it works.
I suppose my other one has a blown up I2C... which sucks
How do I RMA it?
Alan
iotexpert.com
Post by iotexpert.com » Wed May 09, 2018 4:01 pm
Turns out that there is some bug in 2.10xx firmware... and in fact 2.9xxx firmware.
A workaround to unbrick the display is to install 2.4 firmware... then reinstall 2.10
Post by Daniel Divino » Thu May 17, 2018 11:05 am
Hi Alan,
I'll do additional testing with a GTT running the most recent firmware release to see if I can brick the i2c port.
