Toggles
Soinclined
Toggles
Post by Soinclined » Tue Oct 31, 2017 2:28 pm
I have set up four Rectangle Text Toggles with the GTT Designer, and I'm watching the serial line on RealTerm.
When I press a toggle, there's a serial output (252 135 0 2 0 x) where x is the toggle number 0-3, but when I press it again, there's no serial indication that it's back "up".
How do I add an indication that it's toggled back? If there's a drop down for this under Events, I'm not seeing it.
Engineering: It's like math, but louder!
Re: Toggles
Post by Daniel Divino » Tue Oct 31, 2017 2:54 pm
Hi Soinclined,
In order for the GTT to report region "up" events, you will have to change the Touch reporting using command 11.4
If you change the GTT's touch reporting to mode 7, the GTT will report both "up" and "down" events.
Soinclined
Re: Toggles
Post by Soinclined » Tue Oct 31, 2017 3:20 pm
That did it!
Thanks!
