GTT 5 and 7 Rounded rect missing corners
grnbriar
Post by grnbriar » Thu Feb 19, 2015 9:33 pm
I have noticed on both of these displays, that if you use the rounded rect function on the right half of the screen the the two rightmost corners are missing, while those on the lef tside of the screen are fine.
Is this a known bug?
Re: GTT 5 and 7 Rounded rect missing corners
Post by Clark » Fri Feb 20, 2015 12:55 pm
Hi grnbriar,
I appreciate you bringing that issue to our attention. It has been solved and a fix will be included in the next firmware release.
Thanks again,
grnbriar
Post by grnbriar » Thu Feb 26, 2015 6:01 pm
Is the firmware updateable when this fix is in a release?
Or will it be possible to find out when the next release is available before ordering my next samples?
Post by Clark » Fri Feb 27, 2015 11:57 am
Hi grnbriar,
Yes, all GTT firmware is field upgradeable. You'll simply replace the upgrade.bak file on your SD card with the most recent version from http://www.matrixorbital.ca/software/GTT2.0/GTTFirmware, and cycle power.
Post by Clark » Mon Apr 27, 2015 11:56 am
Note: A fix for this issue has been released with firmware version R2.3.0.6632.
Download it here: http://www.matrixorbital.ca/software/GTT/Firmware/
