2 into 1
darkvader71
2 into 1
Post by darkvader71 »
Hello my coding is not great and I am stuck.I have a code that shows when wmp is PLAYING as i have a dell premium remote that has wmp services on in the background so wmp running will always be true,
somehow i made this and it worked
CustomItems.Key1qq
String status = ((String)GetData("WMP9.Status"));
int fi = status.IndexOf('\'');
if ( fi == -1 )
{ // no track playing
if ( status == "" )
{ // wmp not open
return "false";
return "false";
int li = status.LastIndexOf('\'');
String track = status.Substring( fi+1, li-(fi+1) );
return "True "
I also have a custom screen which i want displayed all the time except when winamp(being monitored in application monitor) or my CustomItems.Key1qq(windows media player playing)
how do i combine both functions to triger custom screen? any help will be nice.thank you
Create a new custom item where you logic or the two?
darkvader71
i tried this but when winamp opens,I get an error. :oops:
if(((Boolean)GetData("AppMonitor.Winamp.exe.Running"))&&((Boolean)GetData("CustomItems.Key1qq.true"))) return true;
else return false;
if anyone can help I would appreciate as this is driving me crazy
darkvader71
hello,any help? anyone?
What error does it give you?
darkvader71
i get false when windows media player is playing but should be true & when winamp is running i get this error
Unknown:System.InvalidCastException: Specified cast is not valid.
at ScriptedDataItemImpl.eval()
all i want to acheive is my custom screen running when either winamp or key1qq( windows media player playing) is not. I do not want them cycling every 5 seconds. so basically
winamp running= winamp screen
Key1qq( wmp playing= wmp screen
wimamp or Key1qq not running + custom screen
darkvader71
darkvader71
darkvader71
darkvader71
wimamp or Key1qq not running = custom screen
Try removing the quotes from true and false , you returning strings now
darkvader71
[quote]Try removing the quotes from true and false , you returning strings now.
Hello Ray
sorry did not understand your comment "Try removing the quotes from true and false , you returning strings now".
I think i must inform you that I a new to coding. do you mean like this below ?
if(((Boolean)GetData(AppMonitor.Winamp.exe.Running))&&((Boolean)GetData(CustomItems.Key1qq.true))) return true;
else return false;
(yes i am a noob) :D
darkvader71
can someone help with acheiving this as my coding keeps presenting errors.
Thankyou[/quote]
Did you remove them as well from your CustomItems.Key1qq ?
darkvader71
Ray I know you are a very busy man but like I said, I copied this coding from a forum and changed the manes of the items.
I do not poses any coding skills so if you could find the time to correct codes above and paste here or pm me I would be very greatful. this issue is the only outstanding item of my project( which can be seen in the gallery section. Thank you
