GX Typhoon and GX Typhoon MCE
Aloha
Post by Aloha »
What is the difference between GX Typhoon and GX Typhoon MCE other then MCE remote? I already have my own MCE remote and blaster cable. Does GX Typhoon basic version have an IR sensor and IR blaster cable connector? Will I be able to use my MCE remote and my MCE IR blaster cable with GX Typhoon basic version?
Both have the IR sensor, but like you said, the MCE version comes with the remote, otherwise they are the same.
Aloha
Post by Aloha »
And what about IR blaster cable output?
Another question: will I be able to disable the Typhoon IR sensor and use the original Microsoft USB sensor with TWO blaster outputs?
