No Display on Mos-al-162A
Posted: Sat Jul 07, 2007 10:48 pm
by x40
I have two Mos-al-162a.
After some programming
from one of them ,nothing can be display now
only very dim back ground is seen.
Speed is 9600 ,mode is TTL.
The programmation come from a pic 16f877a.
If exist some firmware ,software to reniatialize to default ??
Or if i have to send it back to the dealer ?
I have already test with Display Tuner R. v0.7 Software and no result.
Posted: Mon Jul 09, 2007 9:56 am
by Raquel
Hello x40,
Thanks for your post.
I am sorry to hear about the problem you are having with one of your MOS-AL162A. When you said you connected with Display Tuner (uProject), and got no results, did you by any chance remember to connect via RS232, unless you have an RS232 transceiver in between the PC and the display?
Posted: Mon Jul 09, 2007 6:18 pm
by x40
I know difference between Rs232 and TTL.
I check with my other display and everything is ok.
Nothing can be display on the other one.
I think is sick ??? or the Eprom is erase ??? or ???
Posted: Mon Jul 09, 2007 8:50 pm
by x40
The problem is this. When powered on , I simply get one row of blocks on the 1st lines of the LCD very very dim.
Any ideas? I've tried both RS232 9600 and also tried TTL settings on my Basic Stamp which I wasn't able to do any commands at all.
Any ideas?
Are there any way for resetting memory or settings to default With firware or flashing programme or software ?
Thanks in advance for your help.
Regards,
Posted: Tue Jul 10, 2007 9:57 am
by Raquel
Hello x40,
It does sound like something is indeed wrong with the hardware. Please email
support@matrixorbital.ca for your options to fix the display.
