MOS-AL202C-YX3SJ and Custom chars problem
Posted: Tue Jul 18, 2006 1:50 am
Greetings to all
Im making a project that will need about 20 LCDs that will take infos thru serial cables and present diferent things in each display and i started by using the MOS-AL202C i ordered and connected the
1 x MOS-AL202C-YX3SJ
1 x Communication and Power Cable
1 x B2021-BK (black)
power on and all looks nice
i tested with uproject and i could write in the screen and even get some bars doing some demos
i then setup the LCDC and used the definition file for the display, LK202-25
it started to work ok and displaying all the screens but with a problem
all custom chars are not correct, even in the Uproject when itry to use the clock its not correct and its unreadable
even when i try thru the manual procedure to make some custom chars are not what i send them (maybe im not doing it ok)
i thought that with LCDC the custom chars should display ok but they dont :/ what ever i tryed
is there any solution something i should do ?
the display in all other areas works fine (contrast/brightness/other commands like clear or send text)
its like the memory for the custom chars is not working or something
thanks again for your time
