Page 2 of 2
Plugins
Posted: Fri Apr 15, 2005 6:56 pm
by Derelique
Another question....can I use plugins that I see at LCDC website with LCD smartie? Or they are not compatible??
Posted: Mon Apr 18, 2005 2:14 pm
by PilchY
got my hnads on a LK202-24-USB - WB and i need to get a copy of the drivers to install the equipment so that LCD smartie can pick it up... anyone help me?
Re: Plugins
Posted: Tue Apr 19, 2005 9:55 am
by Henry
Derelique wrote:Another question....can I use plugins that I see at LCDC website with LCD smartie? Or they are not compatible??
Hi Derelique,
No, LCDC plugins will not work with LCD Smartie and vice versa.
Posted: Tue Apr 19, 2005 9:57 am
by Henry
PilchY wrote:got my hnads on a LK202-24-USB - WB and i need to get a copy of the drivers to install the equipment so that LCD smartie can pick it up... anyone help me?
Hi PilchY,
Thanks for getting a LK292-24-USB-WB, the drivers are located in the hardware forum, under a stickied thread called USB DRIVERS!!!
http://www.lcdforums.com/forums/viewtopic.php?t=1016
If you have any problems, post there.
two mx6 lcd screen vs software.
Posted: Sat Jul 16, 2005 9:00 am
by G78
Just wondering, if i bought another mx6, and put it in the same pc... would i be able to program them both seperatly withought any problem with lcdc?
Posted: Mon Jul 18, 2005 9:53 am
by Tom
G78,
You will just need to open up another LCDC. This will create another LCDC application. You will then set up the unit for the correct definition file and com port in the Configuration/test section. Test out the unit, and you should be good to go afterwards.
:D
Posted: Mon Jul 18, 2005 6:38 pm
by G78
Ok, so 2 time LCDC software open..
One for each lcd screen...
How would it recognise each one seperatly, if it was two identical MX6?
Do they use a different coms port each?
Posted: Tue Jul 19, 2005 12:32 am
by Henry
G78 wrote:Ok, so 2 time LCDC software open..
Yup, each MX will create its own virtual COM Port.
Posted: Tue Jul 19, 2005 8:59 pm
by G78
thats another question.. how much ressources lcdc and MX6 takes to run smoothly... How would it run with two? Could there be bugs appearing having two running at the same time?
Like right now.. MX6+lcdc and the zephyrus kit... they really dont like each others.. Or the drivers for the zephyrus really sucks.
Posted: Thu Jul 21, 2005 10:14 am
by Tom
G78,
When you open another LCDC, it will be opened as a seperate LCDC, and the icon will have a number over it to indicate the different LCDC applications. LCDC doesn't take much resources, but it will also depend on what plugins or amount of plugins the program is using. You would be able to find better answers to LCDC at the LCDC forum at http://forums.lcdc.cc/index.php?showforum=6
I have ran two LCDC applications, and I haven't had any problems with it though.
