Input Lag LK204-7T-1U
Posted: Fri Sep 07, 2018 1:12 am
by mwagner
Hello Matrix Orbital Team,
i need help with button input from LK204-7T-1U USB-Serial to a CentOS virtual machine. I used the C++ Input/Output example on your website and altered it to fit for linux. I edited the polling to be able to show in real time when pressing a button, showing me which button is pressed. The problem i'm having is that it works the first time maybe even the second, but when exiting (closing the lcd) and recompiling and starting it again, it simply doesnt work at all. It seems like something is on sleep or blocking the transmission. Could you maybe provide me with information on how to correctly setting up the serial port on linux to get real time input? I even executed the command: "setserial /dev/<tty_name> low_latency" to minimize the latency. If you need further information please tell me.
Greetings
Re: Input Lag LK204-7T-1U
Posted: Fri Sep 07, 2018 1:58 am
by mwagner
UPDATE
I just figured out, that the method PollKeyPress(key_pressed) returns -1 when no inputs are recognized. Can someone tell me why it returns -1?
Auto Transmit Key Presses is turned off, so it should only return 0 if no button is pressed and 1 if a button is pressed.
Posted: Mon Sep 10, 2018 4:37 pm
by Daniel Divino
Hi Mwagner,
I apologize for the delay in response. We have a Linux appnote that may be referenced when creating applications on Linux. The appnote is developed for an LK162-7T display, but you can still take a look at how the communication port is created.
You can download our Alphanumeric C Library Appnote here: https://matrixorbital.ca/c-library
Also, If you could provide some of your code, we may be able to test it for you here.
