Connecting to internal Mobo header/usb
daitern
Post by daitern » Mon Nov 21, 2016 7:45 am
Hi there,
I bought the B2021-BK , the 5.25 inch drive bay panel with usb connectivity, I would like to know which type of cable do I need to connect to the internal header of the mother board a 9 pin header or 5 pin ? And if so will I have problems with the drivers whatsoever since the included data cable is a standard usb to usb mini. Also if I don't find a one cable do conversions will work , I mean internal header cable to standard usb with adapter to mini. Sorry for writing too long But I need to make a clean cable manegment in my pc so external cables are a no no. Thanks again.
Edit: The display is an LK202
Re: Connecting to internal Mobo header/usb
Post by Daniel Divino » Mon Nov 21, 2016 9:06 am
Hi there daitern,
Welcome to the forums.
I understand you would like to use an internal motherboard cable to connect your PC Bay insert display to maintain clean cable management. We offer an internal 4 pin to mini-B USB cable that you can plug directly to your motherboard, and feed to your display. The cable can be found here: https://www.matrixorbital.com/product_i ... ts_id=1124
Cheers
daitern
Post by daitern » Tue Nov 22, 2016 4:59 am
Thanks that was really fast , btw does it supply power also aside from data or do I still need to feed power with the FDD cable as well? Thanks again.
Post by Daniel Divino » Tue Nov 22, 2016 8:26 am
Hi daitern,
The cable can supply power from the motherboard directly to the display. The four pin header on the cable will connect directly to Ground, Data +, Data-, and 5V. There should be no need for additional cables.
Users browsing this forum: No registered users and 6 guests
