Draw Bitmap Directly Command / Protocol
mbjorge
Post by mbjorge » Fri Jun 20, 2014 9:22 am
I am uncertain as to the exact bytes that I need to be sending in order to using the draw bitmap directly command for the glk19264-7t-1u.
I know that I send the command and the x,y,w,h values. I am confused as to what I need to send for the actual bitmap (the data). The manual says to reference the file upload protocol, but this includes sending command prefix, upload commands, reference IDs, and size parameters, which I feel like I don't need to send? Based on another post (viewtopic.php?f=1&t=3931&p=19276&hilit= ... tly#p19276) it is unclear if the display echoes back the data sent and if I need to send confirmation bytes.
Can anyone tell me if this is correct:
--BEGIN--
0xFE (Command prefix)
0x64 (Draw bitmap directly command)
[X]
[Y]
[W]
[H]
Data[0]
<Display echoes Data[0]>
0x01 (Confirmation Byte)
Data[1]
<Display echoes Data[1]>
Data[n]
<Display echoes Data[n]>
--END--
Thanks!
Tino
Re: Draw Bitmap Directly Command / Protocol
Post by Tino » Fri Jun 20, 2014 9:52 am
Hi mbjorge,
If you are uploading a bitmap then you should refer to the Upload Protocol.
But if you are drawing directly like in you example then you do not need a confirmation byte.
The data of the bitmap consists of the Header which is the width and height of the bitmap. Your comand should look like:
0xFE
0x64
[X]
[Y]
Data
For example to draw the happy face bitmap in the manual example your command should look like:
0xFE
0x64
[X]
[Y]
Data[0x05,0x04,0x50,0x22,0xE0]
This will write the bitmap to the display to where ever the X,Y coordinates are.
Thank you for posting on our forums.
Regards
Martino
Martino DeLeon
Users browsing this forum: Bing [Bot] and 13 guests
