What is IFER ?
firehorse
What is IFER ?
Post by firehorse » Wed Mar 19, 2014 6:55 am
I have emailed LCDC about this question, no reply still
I thought I'd ask here as I'm using the MO vfd and it may have some relation to the error
In LCDC the network traffic shows " IFER "
everything else like i.p and username work but not any net traffic up or down or totals
I read some posts about IFER but no answer was given but someone said something about " IFER is an interface error as the interface number is illegal "
What is this " interface number " ?
Is it possible the MO unit cannot read the lan hardware ?
Or is it strictly a software issue
cheers
Adrian
Tino
Re: What is IFER ?
Post by Tino » Wed Mar 19, 2014 9:03 am
Hi Adrian,
This may be a software issue. Reading the forums on LCDC's site it seems that way.
But if you could give me some info as to what plugins and how your screens are set up I could try to replicate here to see if there is in fact a solution.
Martino
Martino DeLeon
firehorse
Re: What is IFER ?
Post by firehorse » Wed Mar 19, 2014 9:48 am
Hi Martino
Using Windows 7 64
Plugins aren't installed yet but do work as I have tested this before
In LCDC I go to Screen builder > choose screen > select lines > select variables
then I choose 'system' > network > currently > uploading or dwnloading
message at top of popup window says ="IFER"
also CIP - card IP adress is also showing "IFER"
no other issues
Tino
Re: What is IFER ?
Post by Tino » Wed Mar 19, 2014 12:43 pm
Hi Adrian,
This is a software issue.
I've tried allowing LCDC through my firewall and this still did not fix the issue.
I will continue to look at this, time permitting.
If you come to a solution please feel free to post it here.
I will do the same if I find one myself.
Thank you
Martino
Martino DeLeon
firehorse
Re: What is IFER ?
Post by firehorse » Wed Mar 19, 2014 10:47 pm
Ok then
thanks Martino for your help
cheers
firehorse
Re: What is IFER ?
Post by firehorse » Sun Jun 08, 2014 12:55 am
so far no cigar
Will this error cause damage to a motherboard
I'd like to use LCDC still but without the network info
Tino
Re: What is IFER ?
Post by Tino » Mon Jun 09, 2014 8:27 am
Hi Adrian,
So far I haven't found a solution to this issue no.
Also this should not cause any damage to your motherboard.
Thanks for posting on our forums.
In the mean time if you do find a solution please feel free to share it here.
Martino
Martino DeLeon
firehorse
Re: What is IFER ?
Post by firehorse » Tue Jun 10, 2014 6:42 am
Thanks Tino for the reply
how does the network info actually work ?
Why wont it damage the mobo ?
Tino
Re: What is IFER ?
Post by Tino » Tue Jun 10, 2014 10:28 am
Hey Adrian,
All Network Info is doing is reading data from a specific location. Which is the reason you are getting the IFER error as well because the data is not in the location the software is looking for.
It wont damage your motherboard because it is only reading data.
Here is a link to the LCDC forums that may help you with the error as well:
http://arduino.cc/en/Reference/Libraries
Thank you
Martino
Martino DeLeon
firehorse
Re: What is IFER ?
Post by firehorse » Wed Jun 11, 2014 8:53 am
Ahh yes of course Arduino ! I forgot I used to write code for that
Thanks Tino for the help
Tino
Re: What is IFER ?
Post by Tino » Wed Jun 11, 2014 8:57 am
Hi Adrian,
sorry I posted the wrong link there. It was supposed to be this one:
http://forums.lcdc.cc/index.php?showtopic=3815
My apologies for the confusion.
Martino
Martino DeLeon
firehorse
Re: What is IFER ?
Post by firehorse » Wed Jun 11, 2014 8:12 pm
Yes I saw that thread, in fact I scoured the web for anything to do with IFER
Tino
Re: What is IFER ?
Post by Tino » Thu Jun 12, 2014 8:39 am
Hi Adrian,
Thank you
Martino
Martino DeLeon
Users browsing this forum: No registered users and 15 guests
