GLK19264-7T-1U-USB / mogdsharp
abrown
Post by abrown » Fri Nov 08, 2013 8:48 am
Hi all,
I am having an issue with the mogdsharp software with a GLK19264-7T-1U-USB. We've been using these LCDs in our appliances for several years with no issues. However, in a current build, when loading bitmaps and fonts into the LCD memory using the mogdsharp software, we get the following error:
There was a problem uploading the Image to the device..(Read Timeout)
The COM port and Baud Speed are both set correctly. One thing I did notice is that the only option for PCB Revision is 1.x. This is one of the new boards (with "a" appended to the model number), so I was thinking that may have something to do with it. Any thoughts?
Tino
Re: GLK19264-7T-1U-USB / mogdsharp
Post by Tino » Fri Nov 08, 2013 9:28 am
Hi abrown,
To better understand exactly what is going on with your GLK19264-7T-1U-USB I just have a couple questions.
Does Mogd# detect the display when you use the "Auto Detect Display" feature?
Can you write text to the display or draw to the display?
Martino
Martino DeLeon
abrown
Post by abrown » Fri Nov 08, 2013 10:38 am
Thanks for the quick response. :)
When I Auto Detect Display, it does automatically detect the module. I can send text to the display with no issues. I have not tried drawing yet, but will do so shortly and let you know the result.
Tino
Post by Tino » Fri Nov 08, 2013 10:51 am
Hi abrown,
Ok that's good.
Can you try running Mogd# as administrator and moving the Mogd# folder to your desktop. This could fix the issue.
Martino
Martino DeLeon
abrown
Post by abrown » Fri Nov 08, 2013 11:00 am
Thanks Tino, that seems to have resolved the issue. :)
Tino
Post by Tino » Fri Nov 08, 2013 11:03 am
Perfect!
Martino
Martino DeLeon
Users browsing this forum: No registered users and 12 guests
