example: Sending text from LK202-25 with Visual Basic 6
ourstreaming
Post by ourstreaming »
I am learning Visual Basic. I just want to attach commands to the keypress using visual basic without learning c programming.
I want to send serial commands to serial devices such as ipod,projectors stepper motors, etc.
Has anyone used Visual Basic to do this?
Leon
Hi Leon,
Let's see what all-wise Google says...yes, Microsoft has a support page for that. Please take some time to learn the code you wish to deploy in your project; it will help you discover the limitations of your design and build on it's strengths.
Thats vb.net though, vb6 got released in 1999, microsoft's official support ended somewhere in 2005. You might be better off learning vb.net instead since thats still a supported product.
ourstreaming
Assign Keypad Codes 0xfe oxd5[KDown][KUp]
I am almost afraid to post again because you keep sending me some where else.
I promise that this is my last try.
When I press the up arrow key on the keypad, yes it does send a 'H' to the serial port. That is why I brought your product in the first place.
I want to change that 'H' into "Hello world"
MSComm1.Output = Chr$(&HFE) +Chr$(&HD5) [KDown][KUp] + ("Hello World") + Chr$(13)
Leon
Hi Leon,
The LCD will only ever respond with one byte, your host will receive that byte and initiate a desired action; sending hello world to the screen or another device perhaps.
ourstreaming
Thanks Troy,
Now I understand.
Leon
ourstreaming
new lk204-25
Just purchased a lk204-25 from mouser.
The screen lights up but there is no logo text nor can I send text.
Is there something that you can suggect before I send it back.
Leon
Re: example: Sending text from LK202-25 with Visual Basic 6
Hi Leon,
If you haven't tried it already, I would recommend the manual override procedure outlined in your manual. And, if you aren't already, I would also recommend testing with a known good piece of software. For an alphanumeric unit, uProject is a good place to start.
Finally, if this turns out to be a hardware fault, please send an email to support@matrixorbital.ca with the serial number of your unit (##M##-####) and a reference to this thread, then we can get started on an RMA for repair.
