bootmessage / bootimage
Gerd
Post by Gerd »
How can I configure or replace the Matrx Orbital image with my own message?
Thank you Gerd
Hi Gerd,
The easiest way to configure a start screen is probably boot edit. You can also check out the custom character and start screen commands in your manual for for more information or to send the raw data yourself.
Gerd
does it work for glk as well?
Post by Gerd »
but it's a glk
My apologies Gerd, to change the start up screen on a graphic unit, upload a new bitmap to slot or ID number 1. MOGD# is a great tool to do this, and explore many other aspects of our graphic displays.
Gerd
Post by Gerd »
Yeah, works! Thank you.
I did not find this info in the manual. Maybe you should add this ;-)
Thank you
Gerd
Good to hear the start screen is working Gerd, I have ensured this piece of information will be visible in the next manual revision.
