I recently dusted of my VFD2041, which is probably one of the first revisions (about 10 years old). I've done some development for the display and it has worked OK for about 2 weeks. Upon installing in its intended location, I noticed it no longer displaying the flashing cursor when power is applied. I took particularly care making sure it received exactly 5 volts. I fried a different VFD2041 years before because of incorrect voltage and it also stopped displaying a flashing cursor.
My question is: when power is applied to the VFD2041, is it always supposed to show a flashing cursor? Could my VFD2041 need some kind of reset, or is it fried somehow?
Marty
VFD2041 fried?
Hi Marty,
The VFD2041 has a flashing cursor feature which can be turned on or off, hopefully it has just been shut off.
Give a few text commands a try, and if you are really uncertain of correct operation, go back to the old set up and try there first.
Thanks, I will try this, but I thought that the unit would reset all settings when powered off, so the cursor should be blinking when it is powered up.Clark wrote:Hi Marty,
