I'm working on a GLK19264-7T-1U and am trying to upload fonts from Mogd#. I have gotten the "clear" font to upload correctly and am trying to upload an inverted version using the "invert font" checkbox. The font seems to upload correctly except that the charspacing is not inverted. So between every character there is a white line instead of a completely black background. I am working in Mogd# version 1.0.33, which I believe is the most up-to-date version. Is there some work around for this, or a way to fix the problem? I tried drawing a black rectangle behind the text, but it still draws white lines for the charspacing. Thanks for any help!
MOGD# Charspacing on Inverted Fonts
Solution
I am using a PIC18F to control the LCD, so mogd# is only being used to upload fonts. I'm not sure if that would have worked or not, but I did find a solution. I found that setting the box space mode to 'off' fixed the issue. Thanks for your quick reply though.[/quote]
