Old MX610 display can't get the display to light
Aymincendiary
Post by Aymincendiary »
I have an old MX610 PLED display I'm trying to install in Vistax64. Device manager says it's installed correctly, however the display is dark. There seems to be no new drivers for this display since PLED has been discontinued. The micro disk that came with the display is reading corrupt by both my DVD drives. :jawdrop:
Any workaround? This display was fixed by Matrix Orbital back in 2007 under warranty, however I haven't used it since then.
Thanks!
Chris
Hi Chris,
Try out uProject and see if you can communicate and control the display, change the brigthness using the brightness slider.
As per the micro disk, it has a copy of LCDC. If there is no way you can read it, download a new copy from LCDC. The sticker on the micro disk is important though, that is the license key.
Thanks and Best Regards,
