LK202-25 Manual Override problem
dadir
Post by dadir »
I used manual override to set the BAUD rate and unlock the display but, the display is not able to remember the setting after power cycle. Please guide me !!lem
dadir
Re: LK202-25 Manual Override problem
Post by dadir »
hi,
What is the difference between DATA LOCK and SET AND SAVE DATA LOCK?
Both are listed as remember "always". Is'nt remember always same as save?
Please enlighten me!!
dadir
Hi Dadir,
Thanks for the question, I will do my best to guide and enlighten. First of all, you are right, the DATA LOCK command is incorrect in the manual, it should read remember "yes", I will be working to fix that shortly. As for the SAVE DATA LOCK command, you may be experiencing a known problem if your firmware is older than V.5.9. This link will have more information on the problem. You can check your version using the READ VERSION NUMBER command in section 12.2 of your manual.
If you have any questions regarding your firmware let me know,
